Electronic transformers
This redesigned series of electronic transformers complies with the new UL standard (2108) for low-voltage lighting systems
Aug. 24, 2007
This redesigned series of electronic transformers complies with the new UL standard (2108) for low-voltage lighting systems. Using an enhanced “auto reset” function, the transformers are protected against normal and abnormal short circuits for at least 8 hr. In addition, soft-start technology protects both lamps and transformers on cold start-ups. According to the company, the units have been reduced in size by 25%. Heat dissipation of their internal components has also been improved, as well as their reliability and effectiveness. If the case temperature rises above 120°C, the transformers will automatically shut down and continue to cycle until the temperature falls below the 120°C threshold.
W.A.C. Lighting
For more information, visit www.waclighting.com/
