Focus on Truck Accessories
New product spotlight on truck accessories and construction equipment for electrical contractors, electrical engineers, and plant facility personnel
Truck racks
These DeWalt T-branded commercial racks are designed for use on Leer commercial truck caps. Made from extruded aluminum, the racks feature a low-profile design with an articulating base that allows mounting on uneven surfaces. Rated to carry 500 lb, the products incorporate an aerodynamic load bar with a rubber insert to provide load support and protect equipment from damage.
Truck Accessories Group
Circle 300
Underbed boxes
Jobox steel underbed boxes now feature a drop-down door. Available in white or black, the boxes include quick-release keyway connectors, 3-point locking system, ¾-in. rain gutter, and rotating T-handle with reinforced cam lock. The product also features 3-in.-long, ⅞-in. outside diameter hinges with a ½-in. diameter stainless steel pin. Mounting brackets are available.
Delta Consolidated Industries
Circle 301
Side boxes
These low-profile side boxes are constructed of heavy-gauge aluminum with a choice of clear or black finishes. In addition, the boxes feature the company's Extreme Protection lock to guard against break-ins as well as an Automotive Style Latch for one-touch opening. Available styles include driver side standard (11 in. × 19 in. × 59 in.), passenger side standard (11 in. × 19 in. × 59 in.), driver side short (11 in. × 19 in. × 44 in.), and passenger side short (11 in. × 19 in. × 44 in.).
Weather Guard
Circle 302
Truck caps/tonneau covers
Designed to fit the Ford F-150 truck bed's exact size and shape, these fiberglass truck caps and tonneau covers are painted to match the OEM paint code. Models include the LSII Series custom-fitted hard tonneau cover with Lift Assist gas strut system that facilitates opening and closing; the Z Series truck cap with compound curve rear door and screen vent side windows; the V Series truck cap with front picture window, dark tint side windows, and standard rear door with locking handle; and the Deluxe Commercial Unit (DCU) with fully welded aluminum frame construction. In addition, more than 200 options are available, including door and window configurations, toolboxes, custom ladder racks, and cap height.
A.R.E.
Circle 303
