New Products, December 2011
Aerial Work Platform PowerLift is a lightweight, portable aerial work platform designed to be maneuvered and erected by one person. Weighing 278 lb, users can roll or carry the lift up stairs, over rough terrain, and through standard-size door openings. ...
PowerLift is a lightweight, portable aerial work platform designed to be maneuvered and erected by one person. Weighing 278 lb, users can roll or carry the lift up stairs, over rough terrain, and through standard-size door openings. The basket, mast sections, and outriggers can be detached from the base unit to lower the weight to less than 150 lb. With a lift capacity of 350 lb, the product offers the option of an 18V cordless or corded AC drill to power it to a working height of up to 20 ft.
ReechCraft
Circle 256
Drill/Driver
The PCL180CDK-2 18V Li-ion drill/driver has been enhanced to include a new motor and batteries that deliver 424 in./lb of max torque, which the company says is a 30% improvement over the previous model. The additional torque also provides 25% higher speed with 1,500 rpm in high gear. Weighing 3.8 lb and measuring 8.1 in. long, the tool features a streamlined handle, a 22-position clutch, LED light, and onboard bit tip storage.
Porter-Cable
Circle 257
Occupancy Sensors
These passive infrared (PIR) and dual-technology (Ultrasonic/PIR) low-voltage sensors comes in wall-mount and ceiling-mount configurations. PIR and Ultrasonic line-voltage wall switches are also available, as are 120V, 277V, and 347V power packs. All sensors can be converted to line-voltage use with a power pack (PPK-020/PPK-347) or a power base adaptor (PBA-015).
Encelium
Circle 258
Walk-In Van
The Reach commercial walk-in van features a body designed by Utilimaster atop the company’s NPR chassis and powered by the company’s 3.0-L, 150-hp diesel engine to achieve 35% better fuel economy than a traditional commercial van. The engine and transmission offer a B10 durability rating of 310,000 mi. In addition, the van includes a 151-in. wheelbase with either a 12-ft or 14-ft body and features an interior up to 27 in. higher than conventional vans and a cargo area with 540 cu ft or 630 cu ft of storage.
Isuzu
Circle 259
LED Gooseneck Luminaire
The LGOOSE is a 13W LED luminaire that features a neutral-white color temperature of 4,000K and CRI of 86. Featuring a frosted glass lens, the luminaire is available with angled cone, angled dome, or straight shade designs. In addition, the product exceeds Energy Star requirements for chromatic stability during LM-80 testing.
RAB Lighting
Circle 260
Conduit Fittings
Mighty-Bite Push-EMT fittings make connecting EMT conduit approximately 75% faster than conventional fittings, according to the company. Users simply push a fitting onto the conduit for a secure connection. Constructed of corrosion-resistant zinc, the UL- and CULus-listed fittings are removable and reusable. In addition, their design features precision cast threads and a reversible zinc serrated locknut.
Bridgeport Fittings
Circle 261
freeproductinfo.net/ecm
Busway
Designed to maximize overcurrent protection, Starline fusible busway now offers plug-in units with the Cooper Bussmann Compact Circuit Protector (CCP), a UL 98-listed disconnect labeled with 200,000A SCCR, and UL Class CF CUBEFuse, rated to safely interrupt currents to 300,000A rms symmetrical. According to the company, the busway permits changes to power requirements and physical server locations without shutting off power to other racks or cabinets or changing out the entire plug-in unit.
UEC
Circle 200
LED Troffer Replacement
This entire family of LED-based troffer replacements has been qualified by the DesignLights Consortium (DLC). Powered by TrueWhite technology, the CR14, CR 22, and CR 24 deliver a CRI of 90, up to 110 lm/W, a 50,000-hr life, and offer step or 0V to 10V dimming. The LR24 and LR-24-HE models also feature a lifespan of 50,000 hr and a CRI of 90.
Cree
Circle 201
Digital Multimeter
Compact enough for one-handed operation, the 480 Series digital multimeter features true rms voltage and current measurements, 6,000-count resolution, an analog bar graph, active backlight LCD display, Auto-VLoZ to eliminate ghost voltages, and non-contact voltage detection. In addition, the multimeter offers AC + DC true rms to ensure correct readings where harmonics exist and accurately measures electrical frequency, capacitance, resistance, continuity, and diodes. A built-in alert system notifies users if there is a steadier reading available when the input signal is changing rapidly or is noisy.
Ideal Industries
Circle 202
Safety Goggle Retainer
The Stealth safety goggle retainer is designed to attach to most hard hats and creates a proper, gap-free seal around the eyes. Constructed of materials that resist chemical and ultraviolet degradation, the goggle retainer is available in two models to fit standard, cap-style hard hats and full-brim hard hats. When not in use, the goggles are held securely to the hard hat.
Uvex
Circle 203
Floor Box
The Wiremold Evolution Series floor box allows the same box to be installed in raised, carpet-covered concrete, terrazzo, polished concrete, and wood floors without additional parts or accessories. Boxes are available in 6-gang, 8-gang, and 10-gang configurations for standard, on-grade, and fire-classified applications. A furniture-feed box is also offered. In addition, the modules that support industry-standard single-, double-, and triple-gang device plates can be detached and removed through the top or back of the box. Knockout sizes range from
¾ in. to 2 in, and knockout plates can be removed for increased capacity. Available die-cast aluminum covers come in black, brass, bronze, gray, and nickel powder-coat finishes.
Legrand/Wiremold
Circle 204
Enclosures
In addition to the standard RAL 7035 light grey color, the ARCA JIC enclosure family can now be molded in a specific color matched to the Pantone Matching System, FED STD 595C, or European RAL colors. Comprised of 10 standard models ranging from 6 in. 3 6 in. 3 4 in. to 18 in. 3 16 in. 3 10 in. and available in 120 configurations, the enclosures feature opaque or transparent screw covers or hinged latched cover versions. In addition, the units are manufactured using injection-molded polycarbonate and are UL-listed, NEMA 4X and IP 66/IP 67 rated, and CE certified.
Fibox
Circle 205
