New Products: Infared Thermometers, Ladder Rack Enclosure, LED Luminares & More
Infrared Thermometers
The 62 Max and 62 Max+ infrared thermometers are designed to withstand
9.8-ft (3-m) drops to wood floors, according to the company. Featuring a multi-angle backlit display, the digital thermometers are IP54-rated to withstand rain, splashing liquids, dust, and dirt. The
62 Max has a distance-to-spot ratio of 10-to-1 and measures temperatures from 30°C to 500°C with an accuracy ± 1.5% of the reading. The 62 MAX+ features dual, rotating lasers; offers a distance-to-spot ration of 12-to-1; and measures 30°C to 650°C with an accuracy ± 1.0% of the reading. Both units operate on a single AA battery.
Fluke
Circle 200
Part of the Skinny-Trunk product line, the Ladder Rack Enclosure is a multimedia patch panel that mounts directly to an overhead conveyance. Designed to hold fiber and copper, the enclosure, when fully populated, can hold up to 192 LC duplex ports or 96 copper ports (or a combination of the two). According to the company, the product can be easily mounted by one person.
CABLExpress
Circle 201
LED Luminaire
The BeveLED 2.0 is an interchangeable downlight, adjustable, and wall wash luminaire in one housing. Delivering 2,000 lm at 33W, 1,500 lm at 24W, and 1,000 lm at 16W, the luminaire features CRIs of 80+ and 90+, high R9 values, and beam control options from 10° to 80°. The product also features a tool-less field-replaceable and interchangeable light engine and reflector system. Multiple color temperatures and dimming options are available.
USAI Lighting
Circle 202
LED Emergency Luminaire
The FNES Series of self-contained emergency luminaires is equipped with six white LEDs that produce 540 lm for space lighting applications; for escape route lighting, six white LEDs produce 55 lm. According to the company, the luminaire offers a 60,000+-hr life and is suitable for use in Zones 2, 21, and 22. Features include a corrosion-resistant fiberglass reinforced polyester body with polycarbonate diffuser and a choice of either zinc-plated steel, gray painted aluminum, or 315 stainless steel fixing brackets. In addition, the product is equipped with a built-in automatic self-test system with memorization of tests indicated by LEDs. The lamp performs a self-check once a week for 6 sec and a quarterly self-test of 1 hr.
Appleton Electric
Circle 203
Luminaires
Part of the company’s createchange line, Serrano luminaires feature a 3-element diffuser that combines a performance-optimized center optic with two high-transmission, lenticular side lenses for enhanced efficiency and a batwing distribution. Two center lens options are also available. Compatible with a variety of controls, the luminaires offer a wiHUBB-enabled option that allows them to integrate with Hubbell Building Automation’s wireless mesh network. In addition, a hinged optical system provides tool-less, below-ceiling access to the lamps and ballast.
Columbia Lighting
Circle 204
Stack Lights
Werma modular stack lights are available in 50-mm and 70-mm sizes. The stack lights features a bayonet mechanism that allows elements to be mechanically and electrically connected within seconds and changed without the need for tools, according to the company. Incandescent and LED signal elements are available in five colors and in 24VDC and 115VAC voltages. The 70-mm diameter KS 71 modular IP65-rated model accommodates up to five elements per terminal. Light elements include incandescent, LED, and Xenon tube models. The 50-mm diameter KS 50 modular IP54-rated model accommodates up to four elements with either permanent or blinking light effects. A choice of incandescent or LED light sources is available, as well as an
80 dB audible element.
AutomationDirect
Circle 205
freeproductinfo.net/ecm
LED Luminaire
The WLS28 LED luminaire now comes in white (cool and warm), red, green, blue, and yellow color options and features standard or push-button on/off capability. Offered sealed (IP67/IP69K) or unsealed (IP50), the luminaire is cascadable and includes clear or diffused plastic windows. Featuring a width of 28 mm (1.1 in.), lengths range from 145 mm (5.7 in.) to 1,130 mm (44.5 in.). In addition, the product is offered in several mounting options and bracket styles, including zinc-plated 14-gauge steel swivel mounting brackets that allow 45° pivoting in either direction. An alternative mounting option includes the use of high strength magnets, which eliminates the need to drill holes and allows for repositioning.
Banner Engineering
Circle 206
AC Power Source
The Model 1657 power source delivers up to 1,500VA in selectable output voltage ranges of 135VAC or 270VAC at frequencies from 45 Hz to 450 Hz. Featuring a 19-in. rack-mountable design, the power source offers a universal line output terminal and built-in PFC to provide an input power factor of 0.99 at full load. Voltage and frequency parameters are set via the front panel’s easy-to-use control knob, paired with a bright VFD display that continuously displays the output voltage, current, power, and frequency with a 0.1V/0.01A/1W/0.01-Hz resolution. A remote interface for remote communication through a PC is also included.
B&K Precision
Circle 207
Receptacles
Powertite interlocked receptacles offer NEMA 4X corrosion protection in a compact footprint. Suitable as a drop-in replacement for existing competitor FSQC receptacles, the products feature an epoxy powder-coat finish and are supplied with spring door covers and a screw-on cover. In addition, the UL-listed and CSA-certified receptacles are horsepower rated. Auxiliary contacts are available on all models.
Appleton
Circle 208
Electrical Design Software
Paladin DesignView user interface software provides advanced visualization capabilities for the company’s Paladin Live and Paladin SmartGrid power systems analysis platforms, allowing users to run analyses or monitor a mission-critical facility while they are mobile. The software, which runs on IIS and interacts with SVG using JavaScript, features live WYSIWYG editing, drag-and-drop elements, cross-browser, and cross-platform support.
Power Analytics
Circle 209
UPS Batteries
The PHR Series of batteries is designed for the high rate discharge needs of uninterruptible power supplies. The batteries range from 28Ah at 100 wpc to 140Ah at 500 wpc. According to the company, the products offer a service life of up to 10 yr. Features include a flame-retardant ABS case and cover to UL 94 V-O, precision plate pasting, and computer-guided volumetric electrolyte control.
Power Sonic
Circle 210
LED High-Bay Luminaire
The DuroSite LED high-bay luminaire is UL1598/A- and CSA 22.2-certified and set to undergo CE compliance testing. The 100-lm/W luminaire offers outputs ranging from 8,000 lm to 17,000 lm. Features include instant-on capability that allows the unit to be paired with an occupancy sensor and/or dimmable components. Additionally, the product operates on an integrated universal power supply at 100VAC to 277VAC and is suitable for change-out from conventional HID light sources. The 17,000-lm model is IP66-certified for use in outdoor and wash-down locations.
Dialight
Circle 211
Data Logger
The Simple Logger II Model L104 with Bluetooth Communication is a 4-channel AC current recording device powered by alkaline batteries. Compatible current probes include Models MN93-BK, MN193-BK, or SR193-BK, and full scale ranges from 5A to 1,200A are dependent on probe selection. Harmonic measurements are calculated from 64 samples taken on each AC cycle measured and are available in real-time using the included DataView software. In addition, the data logger stores TRMS measurements at user-programmable rates from eight times per second to one per day. TRMS calculations are performed on a single line cycle. Applications include single-/split-phase and 3-phase load monitoring, neutral and ground current monitoring, intermittent problem detection, machine load monitoring, and fault current detection.
AEMC
Circle 212
LED Roadway Luminaire
The Roadway RM LED Series luminaire produces 6,087 lm in a 3G-rated traditional cobra head. The luminaire features 48 LEDs at 4,800K, which deliver 89 lm per watt. Features include a custom die-cast heat sink and LED life of 48,000 hr (L90)/100,000+ hr (L70). Able to be installed on existing poles and brackets, the product features a Type II medium cut-off distribution, twin clamp mounting with leveling capability, bird shield, 2-door easy service, terminal block, surge protector, and an LED ANSI label. Available paint finishes include gray or bronze textured.
Hubbell Outdoor Lighting
Circle 213
Thermal Imager
Powered by the company’s Redlithium battery technology, the 2260-21 M12 thermal imager features 160 pixel × 120 pixel, high-resolution thermal images; a visual camera for standard pictures; and a temperature range of -10°C to 350°C (F14° to 662°F). Additional features include a 5-button interface and a display that updates the screen image 60 times per second. The product also includes PC software, a 2-GB memory card, 30-min charger, SD card reader, and a carrying case.
Milwaukee Tool
Circle 214
Fluorescent Cove Luminaire
The FCLS-Slim flexible fluorescent cove luminaire is available in standard and reduced output/low wattage outputs. According to the company, the UL- and cUL-listed luminaire can flex and conform to almost any curvature, shape, or length that a factory can manufacture. Offering a lamp life of up to 100,000 hr, the luminaire is available in a wide color selection, including 11 different white hues ranging from 1,900K to 8,300K. Measuring 15/8 in. wide and 23/8 in. tall, the unit is equipped with dimmable electronic ballasts.
Cathode Lighting Systems
Circle 215
Headlamp
The EOS industrial headlamp offers 80-lm output. According to the company, a Maxbright LED allows users to spot a target up to 60 m away and features 121 hr burn time. The waterproof headlamp also includes 3 AAA batteries; high, medium, low, and flash output mode; a rubber strap for hard hat use; and a nylon strap for use as a standard headlamp. In addition, the product meets UL Div. I Class 2 requirements.
PrincetonTec
Circle 216
Cable Reel
Compact, lightweight, and portable, the CR16-14-16 reel accommodates a large amount of power cable and is equipped with a three-conductor, 30A collector ring assembly that is housed inside the reel’s drum. A pre-wired supply cord enables direct live hookup and allows continuous current as cable is payed out and rewound Additional features include a 6-ft power source lead of 12/3 cable; a 15A, three-prong straight blade plug (twist lock is optional); an adjustable cam-lock drag brake, and permanent crank rewind.
Hannay Reels
Circle 217
LED Power Supplies
The Optotronic 25W LED power supply is designed for use in confined or tight LED lighting applications, such as display cases and downlights. Available with factory-configurable output options to power a variety of low wattage light sources, the product is compatible with fluorescent 0V to 10V dimmers and packaged in an HID ballast housing.
Osram Sylvania
Circle 218
