Product Spotlight: Focus on Boxes & Enclosures
This month, EC&M magazine spotlights box and enclosure products from Arlington Industries, Adalet,  Bud Industries, and Thomas & Betts
Television box
The TVB810 TV Box is designed for installations of wall-mounted televisions in retrofit applications. Designed to install horizontally or vertically, the UL-/CSA-listed box accepts standard-style plates with receptacles and decorator-style devices with plates, as well as the company’s entrance plates and hoods. Features include mounting wing screws to secure the box in a wall and a 1½-in. knockout for ENT or other low-voltage wiring. In addition, the product includes cover blanks, a wall plate, cable entry device, and cable connectors.
Circle 300
Explosionproof enclosures
The XCESX Series of Div. 1/Zone 1 explosionproof enclosures is constructed from stainless steel 316L. Suitable for use in highly corrosive environments, the enclosures carry UL, cUL, ATEX, and IECEx approvals for global applications. In addition, the products are available in five standard sizes, ranging from 10 in. × 14 in. × 8 in. up to 24 in. × 36 in. × 10 in. Features include a watertight gasket and stainless steel cover bolts for Type 4X/IP66 ratings, stainless steel hinge kit, mounting panel, removable lifting eye bolts, cover alignment device, cast-on mounting lugs, and internal/external ground screws. A flat plate cover allows for additional working area for viewing windows and operating devices.
Adalet
Circle 301
Dual-compartment enclosures
The DCH Series of dual-compartment IP65 enclosures features an upper compartment with an easily removable, transparent cover that allows users to view meters and other indicators and to access system components that may require frequent maintenance. The lower compartment is designed to protect delicate components and contain electrical components that could pose a touch hazard. Cover styles include screw-on and hinged, and both are sealed with a durable oil-resistant silicone sponge gasket. Five models are offered, ranging in size from 6.34 in. × 6.54 in. × 3.66 in. to 11.06 in. × 11.65 in. × 6.22-in.
Bud Industries
Circle 302
Nonmetallic boxes
The Carlon Draft-Tight nonmetallic box features a flanged gasket and cable entry seals that prevent the free flow of air through the box and eliminate the need for caulking and sealants, according to the company. Designed to meet the 2012 International Energy Compliance Code (IECC), the boxes are constructed of high-strength polycarbonate that will not shatter in cold temperatures or warp in hot temperatures.
Thomas & Betts
Circle 304
