Mike Eby’s 2026 Holiday Wish List
The holidays are here! To help you celebrate, Group Editorial Director Elf Mike Eby has compiled his annual list of products that any electrical professional would love to find in their stocking or under their tree.
Bosch Advent Calendar
Celebrate all month long with the Bosch hand tool advent calendar. The set has 24 boxes filled with surprises and starts with a zipper bag to keep tools organized. Every day, a new durable tool or accessory is revealed, including 176-mm water pump pliers, a stubby bottle opener, a ¼-in. ratchet, five sockets in various sizes, a snap-off 9-mm knife 10 replacement blades, a precision bit screwdriver, eight precision bits (PH000/PH0, SL1.5/2.5, TX5/6, TH8, HEX2), eight regular bits (PH1/2, PZ1/2, SL4, TX20/25, HEX4), extension bars, and adapters.
KNIPEX Plier Set
This three-piece holiday gift set includes a 6-in. TwinGrip, 10-in. TwinGrip, and exclusive 2026 KNIPEX TwinGrip sSnowflake ornament. Designed for KNIPEX enthusiasts and skilled professionals, the tools allow users to easily grip stripped screws and bolts with the front and side gripping areas. The front and side gripping capacities from 1/8 in. to 1 1/16 in., and the three-point system offers reliable front gripping of flat workpieces.
Milwaukee Tool Hand Tool Gift Set
This seven-piece holiday gift comes with seven solutions for a wide range of applications. Each compartment of the set contains a mix of durable, job-site-ready solutions, including the 8-in. Comfort Grip long-nose pliers featuring a 2-in. gripping nose, the 7-in. Comfort Grip diagonal cutting pliers, the FASTBACK compact folding utility knife, and much more.
Greenlee Crimper
The EK1240SLX family delivers 12-ton output to support heavy-duty connectors commonly found in electrical applications. A configurable double-tap activation feature requires two consecutive trigger pulls to initiate operation, helping reduce unintended actuation during positioning and setup. This updated generation incorporates ergonomic weight-reduction improvements, helping reduce fatigue during repetitive crimping. IntelliCRIMP Technology monitors crimping force on every cycle and provides visual and audible alerts if pressure falls below specification, helping ensure consistent, reliable terminations.
Legrand Smart 15A Plug-In Switch
The smart plug-in switch with Matter enables the user to control their lamps or other plugged-in devices and set scenes and schedules from any Matter-compliant smart home platform, whether they are home or not. Combining classic design and advanced functionality with a simple connection to existing smart home solution using a home’s existing wireless network, smart lighting from the radiant registered collection sets the exact lighting the user desired.
Cementex Driver-Style Insulated Tool
The screwdriver DriveHandle is a driver-style insulated tool designed to function like a screwdriver for sockets while providing the electrical protection required for energized applications. Engineered for versatility and control, the screwdriver DriveHandle features a ¼-in. square drive head, a 6-in. insulated steel shaft, and a cushion grip handle for comfort and secure handling in demanding work environments.
Ripley Self-Adjusting Cable Stripper
The US21-7300 600V self-adjusting Triplex VariStrip stripper enables users to strip 1/0 AWG to 350 kcmil AWG underground service wire for an all-in-one approach. Equipped with a safe, recessed blade to prevent potential injury and blade damage, this product features a self-adjusting conductor position relative to the blade for reliable strips regardless of cable brand. It accommodates 0.75-in. to 3-in. stripback length adjustment in a clearly marked window via an oversized knob.
IDEAL Fish Tape
Designed for hard-to-navigate piping with multiple bends, IDEAL Zoom fish tape is made from stainless steel and jacketed in nylonIts heavy-duty 3/16-in. diameter and 1,000-lb tensile strength provide the pulling power required for demanding installations while reducing the risk of kinks or damage. The tape is housed in a durable full-perimeter handle case with a 12-in. reel diameter. The machined metal eyelet at the end of the tape increases versatility, making it easy to attach, pull, and guide wires through bends and long conduit runs.
Fluke Journeyman Diagnostic Kit
The Fluke Journeyman diagnostic kit comes with the TL75 Hard Point test lead set featuring a test lead and probe in one unit with a variety of connections. The kit offers AC/DC voltage measurement of up to 1,000V, AC/DC current measurement up to 10A, and AC current measurements with 302+ up to 400A. Additional applications include thermal diagnostics, commissioning and verification, and integrated electrical plus thermal troubleshooting. The rugged, easy-to-use kit has CAT III 600V safety rating.
Helly Hanson Electrical Hazard Boots
The company has released four new work boots designed for construction and electrical professionals. The Magni TRX line of boots includes a leather upper combined with durable CORDURA re/cor fabric for abrasion resistance, and TPU-welded overlays reinforce high-wear areas. The HH AERO-STRIDE+ midsole features advanced ETPU, infused with nitrogen through a super-critical foaming process. Propriety HELLYGRIP XRC rubber on the outsole provides traction and slip resistance in temperatures as low as -30C/-22F, while a 2.5-mm lug provide traction. A composite safety toe on the two composite-toe versions protect against impact hazards, and the fully metal-free construction makes these boots suitable for electrical environments. The boots also feature reflective details for increased visibility in low-light job sites.
Related
holiday gifts under tree
Festive holiday items sitting on a wood floor
