Low-voltage switchgear
Entellisys is a low-voltage switchgear solution that allows operators to perform most control, monitoring, and diagnostic work outside of the arc-flash protection boundary using remote human machine interface (HMI) options. Designed for 208V to 600V and 800A to 5,000A, the switchgear features a bus differential (ANSI 87B) to provide zone-based protection and detect faults that range from less than the bus rating to the full short-circuit rating of the equipment. It is fully redundant to avoid single-point failure for the system and provides fully synchronized waveform capture from every circuit simultaneously.
GE Consumer & Industrial
For more information, visit www.ge.com.
