LED replacement luminaires
This line of ETL-listed LED luminaires consists of four models. The LEDWSE200-2-4LR is a 4-ft/2-tube ceiling or flush wall-mounted T8 LED luminaire with a wraparound lens. The LEDWSEh200-3-4LR holds 3 tubes, while the LEDGHL310-2-4LR is a 4-ft/2-tube recessed-ceiling or T-Bar T8 LED luminaire. The LEDGHL320-4-4LR model accommodates 4 lamps. All four versions feature high-impact, clear acrylic, prismatic lenses secured by stainless-steel screws as well as a safety switch that allows individual fixture power to be disconnected during relamping or maintenance.
LEDtronics
For more information, visit www.LEDtronics.com.
