Circuit breakers
Series G circuit breakers now offer enhanced ground fault protection and non-fused current limiting breaker modules. Equipped with a built-in sensor and ground fault relay, the company’s Earth Leakage Modules are designed to protect against equipment damage and increase safety by limiting current. Additionally, the current limiter module provides automatic reset after interruption. The molded-case circuit breaker can be reset to restore power to systems without having to find replacement fuses.
Eaton
For more information, visit www.eaton.com/seriesg.
