Current transducers
The ATQ Series of current transducers features an open collector transistor frequency output design. Intended to be used as an input to high speed counter or frequency PLC modules, panel meters or programmable relays, the transducers accurately monitor machine current usage to within ±1% of range. Multiple ranges from 0A to 2A and 0A to 200A are available, and a split-core enclosure eliminates the need to disconnect the monitored conductor to install the sensor. In addition, the devices are suitable for use where no analog inputs are available.
NK Technologies
For more information, visit www.nktechnologies.com.
