Bracket fan/luminaire box
The FBRS4200R plated steel box with adjustable bracket now features higher weight ratings for fans and luminaires installed in retrofit construction. The UL-/CSA-listed box is rated for a 150-lb luminaire or a 70-lb fan when installed on joists spaced 16 in. on-center, and 70 lb for either a luminaire or fan on joists spaced 24 in. on-center. According to the company, bracket ends bite into wood rafters or joists, holding the product securely in place. Additional features include a mud cover and installed NM cable connector.
Arlington
For more information, visit www.aifittings.com.
