Roadway luminaires
Designed for use with Philips CosmoPolis lamps, Estilo roadway luminaires are available with flat glass or sag glass optics to provide IES Type I and II with full cutoff, cutoff, and semi-cutoff distributions
June 9, 2011
Designed for use with Philips CosmoPolis lamps, Estilo roadway luminaires are available with flat glass or sag glass optics to provide IES Type I and II with full cutoff, cutoff, and semi-cutoff distributions. They can be used with 60W, 90W, and 140W Philips CosmoWhite lamps that offer an average color rendering index (CRI) of 65 to 70. In addition, the luminaires include an electronic ballast designed for outdoor use that is fully potted to protect components against moisture and dust. With built-in surge protection, the ballast is offered with LumiStep dimming options, which the company says integrate dimming capabilities without additional equipment. The products may be ordered with 6-hr, 8-hr, or 10-hour dimming, or no dimming.
Holophane
For more information, visit www.holophane.com.
