Solar ID labels
This line of solar installation labels is manufactured based on the parameters outlined in Section 690 of the NEC, for Solar Photovoltaic (PV) Systems, using ultraviolet (UV)-resistant ink, permanent acrylic adhesive, and a base material intended to endure harsh environmental elements
Sept. 21, 2011
Designed to meet current National Electrical Code (NEC) and International Fire Code (IFC) requirements for durability, color, text height, and visibility, this line of solar installation labels is manufactured based on the parameters outlined in Section 690 of the NEC, for Solar Photovoltaic (PV) Systems, using ultraviolet (UV)-resistant ink, permanent acrylic adhesive, and a base material intended to endure harsh environmental elements. Available in preprinted reflective, rating, continuous vinyl, and reflective rooftop versions, an optional hand-applied acrylic laminate is offered for additional long-term protection to printed text.
HellermannTyton
For more information, visit www.hellermann.tyton.com.
