Load bank
The AC6120 is a single-phase, 6kW load bank
May 23, 2012
The AC6120 is a single-phase, 6kW load bank suitable for connection to solar inverters, aircraft inverters, UPSs, or any AC power source. Designed to
be used at any voltage lower than 120VAC with reduced power draw, the 19-in. rack-mount/bench-top unit uses six manual toggle switches with series fuses for each load step, providing 250W resolution. In addition, 115VAC forced-air cooling is provided.
OHM Loads Powertek
For more information, visit www.ohmloads.com.
