CFL/LED dimmer
The Harmony CFL/LED dimmer is designed to operate with single-pole and 3-way circuits
The Harmony CFL/LED dimmer is designed to operate with single-pole and 3-way circuits, features a 450W rating, and requires no derating in multi-gang
applications. An adjustment dial allows users to adjust the bottom of the dimming range for a wide-range of CFL and LED bulbs. In addition, the dimmer features a combination On/Off Decorator switch with a separate slider for dimming control. Each unit includes a green LED that glows, making it easy to find in the dark when switched off.
Legrand/Pass & Seymour
For more information, visit www.legrand.us/passandseymour.
