Utility-scale inverter
The Series 6001 energy storage grid-connect inverter provides high-performance conversion in utility applications for wind, solar, and other heavy industrial power applications
nversion in utility applications for wind, solar, and other heavy industrial power applications by creating a high-performance link between the power source and battery. True low-voltage ride through (LVRT) with proprietary algorithms enables the inverter to run near zero line voltage for extended periods while maintaining line synchronization. High-voltage ride through (HVRT) capability is achieved through conservatively rated components. Rated for 500kW, 1,000kW, and 1,500kW applications, the product’s enclosure is designed to meet a seismic zone 4 rating and is available as indoor or outdoor rated.
Eaton
For more information, visit www.eaton.com.
