• LED power supply
    Designed for landscape applications, Q-SETeLED and Q-SETMLED remote power supplies are listed to be directly buried into the ground
    July 23, 2012
    plies are listed to be directly buried into the ground and mount directly into the company’s Q-VAULT-5, an IP68 listed enclosure capable of being buried into the ground or in concrete. The Q-SETeLED model is available in 60W and 120W, 12VDC or 100W and 200W, 24VDC models, and up to two can fit inside one Q-VAULT-5. The Q-SETMLED is available from 60W to 300W in 12VDC or 24VDC. One Q-VAULT can accommodate up to two of these models. Boost taps provide the ability to recover voltage drop over longer runs, and secondary circuit protection prevents any damage to the LED lighting.
    Q-Tran
    For more information, visit www.q-tran.com.
