Dimension 4 Power Distribution System-II (PDS-II)
The Dimension 4 Power Distribution System-II (PDS-II) provides four 20A circuits to a series of connected workstations
Sept. 20, 2012
circuits to a series of connected workstations. Each of the four circuits is tapped by simply inserting one of the PDS-II 15A Duplex or 20A Simplex outlet modules into the distribution blocks assembled into the Dimension 4 workstation uprights. Outlets are numbered for easy circuit identification, and redistribution of electrical usage is accomplished by exchanging the numbered outlet modules. Outlet modules snap into any of the receptacles incorporated throughout the workstations, and are secured by two screws. When in place, the outlet modules are flush with the uprights to facilitate accessory clearance.
IAC Industries
For more information, visit www.iacindustries.com.
