Interval data recorder
Available in two models, the eight-meter (IDR-8) and the 16-meter (IDR-16) interval data recorders both offer simultaneous dual-protocol communications for integration with multiple BAS systems, billing packages, or M&V reporting
Dec. 12, 2012
This interval data recorder (IDR) is designed for collecting kilowatt-hour (kWh) and
demand (kW) data from up to eight or 16 connected meters at user-selectable 15-min, 30-min, or 60-min intervals. A four-line LCD display shows real-time data, while onboard memory stores up to 72 days of 15-min interval data accessible via modem, Ethernet, Modbus, BACnet, LonWorks TP or MV-90. Available in two models, the eight-meter (IDR-8) and the 16-meter (IDR-16) both offer simultaneous dual-protocol communications for integration with multiple BAS systems, billing packages, or M&V reporting. An optional Screw Terminal feature allows users to gather and store data from third-party pulse-output devices such as electric, gas, water, BTU or steam meters.
E-Mon
For more information, visit www.emon.com.
