Backup generator
The 38RCL residential backup generator features neighborhood-friendly sound levels, an all-aluminum corrosion-resistant enclosure, and uses either liquid propane or natural gas as a fuel source.
Designed for residential applications, the 38RCL backup generator emits neighborhood-friendly sound levels with 61 dB
at full-speed operation with no load and 58 dB at exercise (normal conversation) level. The 38kW generator features a compact, all-aluminum corrosion-resistant enclosure and includes a 5-yr or 2,000-hr warranty. Able to use either liquid propane or natural gas as a fuel source, the product provides fast, flexible installation with easy-to-wire terminal block and breaker, as well as easy-to-connect fuel lines.
Kohler Power Systems
For more information, visit www.kohlerpower.com.
