A19 LED lamps
Omnidirectional A19 LED lamps are dimmable 7W and 10W replacements for 40W and 60W incandescent lamps,
respectively. Featuring a multi-layered tapered heat sink to draw heat away from the LED chips, the lamps provide a 300° beam angle that produces even light in all directions from the LED source. In addition, the products are available with standard Edison and GU24 bases.
MaxLite
For more information, visit www.maxlite.com.
