Dimmable LED drivers
Crestron’s Green Light LED drivers allow dimming to below 1%.
Green Light dimmable LED drivers provide high-power LED lighting with dimming to below
1%. Available in 50W and 100W models with DALI or 0V to 10V control, the drivers use a combination of duty-cycle and current dimming. All 50W models are available with two output channels while 100W models are available with four output channels. DALI-controlled models are available in versions that allow output channels to be independently controlled for multiple LED sources. The 50W DALI models feature two independently controlled outputs, and the 100W DALI models feature two sets of two independently controlled outputs.
Crestron
For more information, visit www.crestron.com.
