Terminal blocks
The Konnect-It terminal block product line includes a variety of models and options.
Konnect-It single-level terminal blocks handle currents up to 175A, accept wiring sizes from 26 AWG to 2/0 AWG, and feature a 100kA SCCR rating. Double-level terminal blocks come in 20A and 30A versions and a variety of colors. Options include LED indicators, diode, and direct cross level connections, as well as models with an added grounding leg. Triple-level terminal blocks handle up to 24A and accept wiring sizes from 24 AWG to 12 AWG. Options include NPN and PNP sensor blocks with LED indication, as well as versions with an added grounding leg. Grounding terminal blocks with screw-down or snap-on clamping ground connections offer low contact resistance and corrosion-free connection points, while miniature terminal blocks are available in 20A and 30A capacities, and are are mountable on 15mm DIN rails. Fuse holder and disconnect terminal blocks enable circuits to be opened or to perform tests while the system is powered.
AutomationDirect
For more information, visit www.automationdirect.com/Konnect-It.
