LED luminaire
Offered in 1 ft, 2 ft, 3 ft, and 4 ft lengths, WashGrazeLVD is a TRIAC dimmable line voltage linear luminaire.
WashGrazeLVD is a TRIAC dimmable line voltage linear luminaire designed for continuous surface grazing and wall-washing applications. Suitable for new construction or retrofit applications, the low-profile LED luminaire operates from 120VAC to 277VAC without remote drivers. When operated at 120VAC, the product dims smoothly with either leading-edge (forward phase) or trailing-edge (reverse phase) ELV dimming controls. Offered in 1 ft, 2 ft, 3 ft, and 4 ft lengths with flexible end-to-end molded connectors allowing continuous runs up to 155 linear feet, the IP-66-rated luminaire features nine beam angles, six white color temperatures, and a 50,000-hr life.
Emerge Lighting
For more information, visit www.emergelighting.com.
