J-Hook
Available in zinc-plated or stainless steel, the Hook H-433 is infinitely linkable and features snap-on tears that require no additional hardware or brackets.
Nov. 5, 2013
The Hook H-433 is a 4-in. × 3-in. spring steel hook with a 2-in.-wide cable bearing surface. Available in zinc-plated or stainless steel, the J-hook holds all types of cables and innerduct with a static load of 100 lb. Additionally, the Plenum-rated product complies with UL, CUL, NEC, and EIA/TIA structured cabling requirements; is infinitely linkable, and features snap-on tears that require no additional hardware or brackets. Other highlights include an integrated wire cage, radiused edges, and color-coded slide-on sleeves that can be applied to designate pathways.
MonoSystems
For more information, visit www.monosystems.com.
