Vapor-tight luminaires
The Ironclad 66 Series of industrial-grade vapor-tight luminaires is rated NEMA 4X, NEMA 5, IP-66, UL, cUL, and is USDA and UL Wet Location approved. Designed for surface or ceiling mount, configurations include: 2-ft two lamp 17W T8 (VT221700), 4-ft two lamp 32W T8 (VT423200), and 4-ft two lamp 54W T5HO (VT425400). In addition, the luminaires offer a dual-input high power factor (HPF) ballast requiring 120V to 277V, pull-in disconnect, clear lens with olive gray housing, and stainless steel latches.
Shat-R-Shield
For more information, visit www.shatrshield.com/fixtures.php.
