Power supply
SolaHD’s SDN 40-24-100C 40A single-phase power supply features visual diagnostic LEDs to indicate I/O status at a glance.
The SDN 40-24-100C is a 40A single-phase power supply, allowing users to add new equipment that can be powered from the existing structure with little or no retrofitting requirements. Features include visual diagnostic LEDs to indicate I/O status at a glance.  In addition, the RoHS-complaint power supply comes equipped with screw terminal connections and an industrial-grade metal outer case that efficiently dissipates heat and delivers full power in a temperature range from -25°C to +60°C.
SolaHD
For more information, visit www.solahd.com.
