Portable generators
2kW inverter monitors power demand and varies engine speed 12.3kW model is a closed-loop electronic fuel injection generator 25% reduction in fuel consumption and exhaust gases (12.3kW model)
Nov. 28, 2013
This portable generator line initially comprises the PRO2.0iS 2kW inverter and the PRO12.3EFI 12.3kW gasoline generator. The PRO2.0iS includes an intelligent sensor that monitors power demand and varies engine speed for improved efficiency. The PRO12.3EFI is a closed-loop electronic fuel injection (EFI) generator that features the company’s commercial-grade Command PRO EFI engine. As a result, users can expect to see up to a 25% reduction in fuel consumption and exhaust gases. This model also features the company’s Accu-Fill angled side-fill design, which minimizes the danger from spillage during refueling.
Kohler
For more information, visit www.kohler.com.
