Monitoring relays
Available with optional push-in technology Provide only a single function Feature a 17.55-mm-wide housing
The EMD-BL monitoring relays are available with optional push-in technology, which connects up to 60% faster than screw termination and has a retention force five times the IEC requirement to facilitate installation, according to the company. Available for single-phase current monitoring, single-phase voltage monitoring, 3-phase voltage monitoring, and phase monitoring, the UL- and cUL-approved relays provide only a single function and feature a 17.55-mm-wide housing. The housings include rotary switches for easy parameter adjustment and status indication LEDs.
Phoenix Contact
For more information, visit www.phoenixcontact.com.
