Transfer switches
RTS Series transfer switches are listed for 30-cycle closing and withstand ratings based on testing per UL Standard 1008. Featuring the withstand capacity to allow downstream devices to clear a fault before upstream devices the switches are available in single- and dual-operator versions in ratings from 100A to 4,000A for either open- or closed-transition switching. In addition, the products are available in load-break bypass and no load-break bypass versions and come equipped a microprocessor-based transfer control system.
Russelectric
For more information, visit www.russelectric.com.
