Motor cable
Double-shielded Available in a four conductor configuration Rated for 600V to 1,000V
March 7, 2014
TOPFLEX 620 VFD XLPE-insulated cable is suitable for applications with high voltage spikes and long cable runs due to its low capacitance. The cable’s PVC jacket is resistant to oils (Oil Res I & II), coolants, and solvents, making it suitable for open, exposed runs (TC-ER rated, UV-resistant), installation in pipes, or in the ground (direct burial rated).In areas where electrical interference may be an issue, the product is double-shielded to provide protection against electrical disturbances (noise). In addition, it is available in a four conductor configuration ranging in sizes from 16 AWG to 2 AWG, is rated for 600V and 1,000V applications, and can operate in temperatures from -25°C to 105°C.
HELUKABEL
For more information, visit www.helukabel.com.
