Threadless grounding bushings
Feature a plastic liner Made of malleable iron Available in sizes ½ in. through 4 in.
The TL Series threadless grounding bushings feature a plastic liner that protects insulated conductors from abrasion during pulling or due to mechanical vibration. Made of a malleable iron, the bushings’ zinc-plated body is designed with a tin-plated lay-in lug that allows for easy installation and alignment of AL/CU conductors where the raceway is required to be grounded. The products are available in sizes ½ in. through 4 in. with multiple lug option.
Bridgeport Fittings
For more information, visit www.bptfittings.com.
