LED engine
Uses only 17W Same diameter as a PAR20 Dimmable to less than 2% on reverse-phase dimming systems
Designed to replace a 39W PAR20 metal-halide and using only 17W, the plug-and-play TLM-R20 LED engine features the same diameter as a PAR20 and includes an integrated driver, eliminating the need for large ballast or driver boxes. In addition, the LED engine is dimmable to less than 2% on reverse-phase dimming systems. Available in 2,700K, 3,000K, 3,500K, and 4,000K color temperatures, beam angles include 15°, 23°, 35°, and 51°.
TerraLUX
For more information, visit www.terraluxillumination.com.
