LED light engines
Uses 50% less power than comparable LED fixtures Front face diameters from 1 in. to 4 in. 50,000-hr life
June 11, 2014
This line of LED light engines uses 50% less power and has a higher center beam intensity (CBCP) than comparable integral LED fixtures, according to the company. Due to their low profile and small diameter, the light engines allow luminaires to be 50% smaller while their heatsink design enables low-temperature operation and a lifetime of 50,000 hr. Title 24 compliant, the products are available in front face diameters from 1 in. to 4 in.; install with standard MR/PAR/AR front mounting rings; are designed to work with an external driver; are compatible with range of dimming and control systems; and are California Title 24 compliant.
Soraa
For more information, visit www.soraa.com.
