Portable LED floodlights
360° beam Illuminates more than 50 ft in each direction Weatherproof for outdoor use
July 17, 2014
The Beacon360 is a 120W LED area light that features a 360° beam for illuminating an entire area at once. The product can light up more than 50 ft in each direction and is weatherproof for outdoor use. The design generates very little heat, doesn’t require a lamp change, and uses 70% less energy than traditional lighting options, according to the company. Made from cast aluminum, the floodlight features polycarbonate lenses, offers a 50,000-hr life, can run at 120V or 240V right out of the box, measures 14 in. in length and 6 in. in diameter, and weights 10 lb.
Lind Equipment
For more information, visit www.beacon360light.com or www.lindequipment.net.
