Industrial timer
The Automatic Timing & Controls Model 175SO-110 is a compact ON-delay industrial timer designed to provide high-accuracy timing control within OEM and industrial applications. Offering a low-profile, DIN-rail mounted outer housing measuring 17.5 mm, the single-mode timer features a 5A SPDT relay output contact configuration, LED indication, and 10 user-selectable time ranges that can be selected from 0.1 sec up to 3 hr. The unit also features a 110VAC (50 Hz or 60 Hz) supply voltage. In addition, the UL-listed and CE-certified product is easily configured for time range and scale setting via front facing knobs.
Marsh Bellofram
For more information visit the Marsh Bellofram homepage.
