Ground rod electrode kit
Complies with UL 467 Weighs 8 lb Installs from ground level with no compression components
Aug. 1, 2014
This ground rod electrode kit complies with UL 467 and is NEC and NESC compliant. The kit contains five parts: two 4-ft copper-coated ground rods threaded on one end of each rod, a 5/8-in. threaded coupling, a 5/8-in. drive stud, and a 5/8-in. UL-listed ground rod clamp. Weighing 8 lb, the product installs from ground level with no compression components.
Galvan
For more information, visit Galvan’s homepage.
