Rubber and watertight electrical products
Includes plugs, connectors, and receptacles Constructed from thermoplastic elastomer Designed for highly corrosive and wet industrial environments
Aug. 18, 2014
Constructed from thermoplastic elastomer, Pass & Seymour rubber and watertight plugs, connectors, and receptacles are designed for highly corrosive and wet industrial environments. Rubber plugs and connectors contain industrial-strength brass blades and contacts that resist heat and provide exceptional conductivity, while two screw cable clamps secure wires and provide superior strain relief. Watertight plugs and connectors resist high-pressure hose downs of 1,500 psi. Nickel-plated blades and contacts offer long-lasting, corrosion resistance. Watertight Receptacles feature a spring-loaded flip cover; stainless steel hinge spring and pin; and impact-resistant Valox lid, cover plate, and receptacle body. Duplex versions offer lockout/tagout capability.
Legrand
For more information, visit Legrand’s homepage.
