Connection kits
Approved by CSA and FM for NEC Ordinary and Hazardous locations Reinforced standoffs to prevent cracking Carbon-impregnated eliminates static charge buildup
Aug. 5, 2014
Approved by CSA and FM for NEC Ordinary and Hazardous locations, AX connector kits are constructed to withstand extreme conditions that would compromise a standard heat trace connector. The nonmetallic, impact-resistant polyester enclosures are rated IP66 and NEMA 4X, making them suitable for use in corrosive environments. The enclosures also feature reinforced standoffs to prevent cracking, along with being carbon-impregnated so static charge cannot buildup. DIN-rail mounted terminal blocks help when maintaining the connection, while spring-clamp terminals simplify wiring with no need to tighten screws. In addition, they fit all wattages of the company’s self-regulating heating cables (LT, HLT, QLT, and CLT).
Nelson Heat Trace
For more information, visit the Nelson Heat Trace homepage.
