Circuit breakers
Emax 2 low-voltage circuit breakers feature integrated energy management functions that monitor power usage and control installed loads and generators. The Ekip power controller is available for the circuit breakers for any application where control of power usage is needed. It monitors power as it flows through the circuit breaker and manages loads to keep total power use below the limit set by the user. In addition, the products include direct communication capabilities for seven of the most popular industrial protocols. Mechanical design features include a frame that occupies less space and adjustable terminals that reduce the need to bend and extend bus bar. The trip unit includes color touch-screen navigation with embedded ANSI codes and a variety of easily installed accessories.
ABB
