Voltage indicator
For use with voltages from 5V to 28V Moisture seal allows for outdoor applications Mounting hole size of 14 mm (0.551 in.)
Dec. 3, 2014
The all-in-one CNX 714FV Series 14-mm indicator offers the company’s FlexVolt technology, enabling it to be used with voltages ranging from 5V to 28V. Featuring a moisture seal that allows it to be used in outdoor applications, the indicator includes fast pitch threads that require only one turn for easy assembly. In addition, the RoHS- and Reach-compliant product is resistant to shock and vibration, is IP67/NEMA 6P, provides direct sunlight visibility, and offers a wide viewing angle for maximum light detection. Other features include a mounting hole size of 14 mm (0.551 in.) and 24 AWG wire leads.
VCC
For more information, visit the product page.
