Cable tray accessories
660QA sheave roller fits on tray rung spaces up to 20 in. (508 mm) apart Cast-aluminum sheave can handle forces of up to 100 lb (45.4 kg) CTR100 and CTR200 cable rollers feature a retained spring pull-pin release
The 660QA sheave roller adjusts to fit on tray rung spaces up to 20 in. (508 mm) apart. The cast-aluminum sheave can handle forces of up to 100 lb (45.4 kg), while a set screw handle locks and unlocks n adjustable sliding leg, eliminating the need to access the top and bottom of the tray to securely attach the sheave. The CTR100 and CTR200 cable rollers assist at heavy load points around 90° bends, offsets, and vertical rises and drops, yet don’t take up space in the tray. The four conveyer rollers securely trap the cable within the guide while not damaging the cable jacket and allowing the cable to smoothly glide through. The rollers also feature a retained spring pull-pin release and steel construction that allows them to withstand cable pulling loads up to 100 lb (45 kg) and 200 lb (90 kg), respectively.
Greenlee Textron Inc.
