Industrial timer/counter
10 operating modes within a single unit Accepts standard voltage inputs of 3VDC to 30VDC Input speeds of 3 Hz, 30 Hz, and 5 kHz
The Model 385AR Series is multi-function, multi-range industrial timer/counter featuring 10 operating modes within a single unit. Designed to accept standard voltage inputs of 3VDC to 30VDC, the timer/counter is compatible with most industry proximity switches, solid-state devices, and potential free contact encoders. Input speeds of 3 Hz, 30 Hz, and 5 kHz are standard. In addition, the device includes a built-in 12VDC 30mA sensor power supply with integral short circuit protection, as well as options for front panel or remote reset. Standard operating voltage range supply is 85VAC/DC to 270VAC/DC (50/60 Hz), with a maximum power consumption rating of 5VA.
Automatic Timing & Controls
For more information, visit the product landing page.
