Storage solution
The Jobsite Organizer includes eight small and two large removable bins that can be mounted on common jobsite materials by using the integrated screw slots. A seal around the perimeter of each bin prevents small items from migrating from one bin to the other, and the 4 in. × 4 in. size of the small bins allows them to be swapped out with a common electrical box. To allow users the option of carrying multiple organizers at once, the product contains side clips that not only allow the units to be attached together, but also provide full access to each when they are stacked on top of one another. For added durability, the unit features a reinforced rib for strength and an integrated weather seal gasket to prevent water intrusion.
Milwaukee Tool
