Cable stripper
Self-contained depth gauge allows precise stripping of wire Spring-loaded retention pin Drill mounting adaptor for ¼-in. quick-connect drills
May 27, 2015
The GTSD-1930 Saber stripping tool features a self-contained depth gauge that allows precise stripping of wire without the danger of exposed blades. The spring-loaded retention pin allows the user to simply pull the pin and insert specific bushing sizes. The retention pin also allows users to quickly change bushings. Cable-specific sized bushings are offered individually and as kits to ensure the precise removal of the cable jacket. In addition, the product incorporates a drill mounting adaptor for ¼-in. quick-connect drills, standard keyless chucks, and can quickly attach to a variety of battery drills with one-handed attachment for most tools.
Greenlee Textron
