Ecmweb 3755 Mulelarge
Mule Lighting Inc. LED-Flex LED Lighting System
Feb. 9, 2005
Category: Lighting Systems Designed to look like traditional neon lighting, LED-Flex lights are UV-protected tubes lined with red, green, blue, or yellow LED lamps. The tubes bend 180° and can be custom cut and shaped on-site. The lights require as ...
Designed to look like traditional neon lighting, LED-Flex lights are UV-protected tubes lined with red, green, blue, or yellow LED lamps. The tubes bend 180° and can be custom cut and shaped on-site. The lights require as little as 1.92W of energy per foot and use a semi-conducting material that converts electricity directly into light. The solid state design enables the lights to withstand shock, vibration, frequent switching, and temperature and environmental extremes. They’re available in 30-ft, 24V and 150-ft, 120V lengths.
Mule Lighting
