Protective ground clamp
FCI-Burndy
The new BURNDY GTC1AC34RA Protective Grounding Clamp is designed to facilitate the installation of grounding sets on pad-mounted equipment. According to the company, the clamp’s 90° right angle design allows the entire grounding set to be contained and protected within the cabinet housing, permitting linemen to close the cabinet door without breaking the minimum approach distance. In addition, the product can be assembled with other protective grounding components, such as cable ferrules and clamps.
FCI-Burndy
For more information, visit www.fciconnect.com.
