Lithonia Lighting Indura 4X Industrial Emergency Unit
Category: Lighting Fixtures
A weather-proof housing on Indura 4X emergency lighting units is sealed and gasketed to protect against water, dust, and dirt found in manufacturing facilities, mills, and refineries. A 12-gauge steel mounting bracket finished with epoxy electrocoat eliminates corrosion, and a UV stable polycarbonate lens protects lamp heads from environmental conditions. Flood, medium, and spot lighting options are possible.
Lithonia Lighting
