Rack enclosure
The Liebert XDK is a 19-in. Knurr rack enclosure with integrated cooling capabilities, which the company says provides cooling for up to 25kW of high-density electronics. The rack enclosure uses air circulation internal to the enclosure that is completely sealed from room air and environmental conditions. In addition, server heat load is absorbed by the rack’s integrated cold water system through a high-efficiency air-to-water heat exchanger in the bottom of the rack.
Emerson Network Power
For more information, visit www.gotoemerson.com.
