Retrofit fluorescent luminaire
The Zipline retrofit linear fluorescent luminaire features an integrated ballast and lamp holder in a self-contained assembly unit
nd lamp holder in a self-contained assembly unit. Comprised of nine separate components in two easy-to-install modules, the product mounts into the existing lighting fixture, bypassing the need to install and wire ballast and socket components separately. Designed to fit into most 2x2 and 2x4 troffers, the product is available in 2-lamp and 3-lamp configurations as well as in high, normal, and low ballast factors.
Leviton
For more information, visit www.leviton.com/zipline.
